Data stopped working
EJA
Hello,for about 5 days now my data has stopped working, I thought I had exhausted everything only to log into self serve and I see that I still have 484.993mb remaining and 1024gb of unused promotion data. I don't understand why suddenly data is not working.
7 REPLIES 7
EJA
It was the dual sim.
@EJA  Good to hear the problem was solved, and since you clicked my post as the solution, now I'm curious about which of the three choices, I threw out there, was the culprit that solved the problem??? 🤔
EJA
Thanks everyone for your contributions. problem solved.
popping
@EJA
If you can call and text in and out, make sure that your data is enabled and restart you phone or airplane mode on/off.
You may test your PM SIM card on another phone just to eliminate hardware problem.
Triguy
When you log into your account - what is the status ?
CannonFodder
Possibly unintentionally turned data off in the settings, while changing something else? Happened to be in an area of poor/zero coverage at the time you were attempting to use it?
Dual SIM phone, and MAYBE connected to a different provider, with no data on that plan?
NDesai
@EJA Can you confirm if other services like call and text are working fine? Have you tried rebooting your phone?
