07-14-2020 06:07 PM - edited 01-05-2022 12:06 PM
Hi,
does anyone know how to check the speed of data that we are getting from our plan?
Thanks
07-15-2020 11:44 AM
@JCN here's how you can tell without using a bunch of data in a test:
07-14-2020 09:29 PM
@Deez13 wrote:best way is to simply go to google.ca then type speed test
The speed test from Google is hit and miss many times for me. It would never give me the max speed when speedtest web app can. I think the speed test tool on Google search page is good for those with low speed.
07-14-2020 06:43 PM
07-14-2020 06:36 PM
07-14-2020 06:21 PM
@JCN wrote:Hi,
Thanks
You can do speedtest. But don't wait your data by running speedtest especially during the first 3 days after activation because you are getting a full LTE speed which will consume your data quickly. Be warned. Don't complain if you are doing speedtest with a plan will small amount of data.
07-14-2020 06:16 PM
Hi @JCN ,
Sign into "My Account", and go to the 4th TAB "Plan and Add-ons".
Is this what you are looking for?
07-14-2020 06:12 PM - edited 07-14-2020 06:18 PM
07-14-2020 06:09 PM - edited 07-14-2020 06:11 PM
@JCN Oficialy, LTE data speed is limited, and it is to 3mb/sec. But you can force your phone to use 3G instead, and its speed can be up to 20mb or even higher depending of signal and how close to the tower you are.
