Data plans.
nigmea
if I'm not mistaken before there were higher data plans then 3g but cost more obviously. is that not offered anymore? I only see 3g data add ons.
thanks
nigmea
I'm grandfathered in then thanks for letting me know!
popping
@nigmea
PM is a prepaid provider,  There is no credit check on your name.  Therefore, you can assume a grandfathered LTE data plan if a owner want to leave PM.  You don't need PM permission to assume responsibility of a PM account.
dabr
@nigmea      Yes those plans plus the BYOP were all discontinued about 2 years ago.  If you were on one of those plans, then you would have been grandfathered in and still get 4G data speed as long as you didn't change plans after they were retired.
0PX9O4
@nigmea
You are correct. Unfortunately PM has discontinued all high speed data plans from before 😞
