Data plan
John-12
How to  check balance  in phone?
@Chanah wrote:
Useful (free) app made by a PM member to check data: https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm&hl=en_CA
Android only for this specific program.  There are other 30 (or 90) day tracker apps out there too for each platform.
Chanah
hairbag1
Log into My Account / Data & Add-ons. If you can't see any data info, that usually means you've reached your limit. You'll need to wait until renewal, or get a $30 data Add-on. You can also change your plan right away but that means losing whatever balance you have in the current 30 day period.
Triguy
Log into your self serve account and next to data and add-ons click on view usuage.  If nothing is showing then you have used up your data.
iliketotalk
@John-12 you go into your account under data and add ons if there is no balance showing then it is used up
