Data plan
Dino007
If I use my data in the US will I be charged extra or does my Can, US, and MEX plan be covered.
Thanks,
2 REPLIES 2
Sansan
No, you will not be charged extra with the Canada-US-Mex plan. You use it just as you do at home.
There is never any extra charges here. The system will simply not work if you don't have the proper plan.
