02-16-2019 03:55 PM - edited 01-05-2022 03:22 AM
Will I be charged data overage charges or will data stop working after my allotted data usage is used up ? Please advise.
05-13-2021 03:08 PM
I was told the same....because I specifically asked about it. Or I would not have switched from the provider i was starting to have problems with.
Literally, I asked more than once. As I have no WiFi where I live. Walked to buddies to use his.
Little hot under the collar now, but I will be discussing this with person where I got sim card from. I already had a sim card from one of the other providers l, so that was $11.30 I would not have spent. . All said and done. I put out $48.20 for something I was lied to about. Or as you put it misinformed. As well I spent about 6 hours time, between going to get the card and vouchers (set up auto pay for next month.) and then setting up account/activating card. Might not have taken as long for others. But after I entered the voucher pins and and saw that the amount owing drop to $0 I hit activate it seemed it didn't work.
I did figure out the problem. But I beginning to think I choose wrong.
02-21-2019 04:46 PM
Unlimited Data Plans in Canada
Freedom Mobile | $15-$100 /month | 250MB to 20GB in Freedom Zones | ~100 Mbps LTE | 256 kbps | Talk, Text and 10GB $60/month |
SaskTel | $75-$125 /month | 15GB nationwide | ~200 Mbps LTE | 2.0 Mbps | Unlimited Data Promo $75/month |
Chatr Mobile | $35-$50 /month (prepaid) | 1-8GB nationwide | 3.0 Mbps 3G speeds | 64 kbps | Talk, Text and 4.5GB $40/month |
Lucky Mobile | $35-$50 /month (prepaid) | 1-8GB nationwide | 3.0 Mbps 3G | 128 kbps | Talk, Text and 4.5GB $40/month |
02-21-2019 04:40 PM
illimited what?
02-21-2019 04:38 PM
@rh66 wrote:Okay... when i was sold this plan i was told that data never stops, just gets limited to beyond slow speed and the reason i signed up. Was this wrong information?
Yes, this is wrong Data will stop working when you have used the plan amount.
02-21-2019 04:38 PM - edited 02-21-2019 04:43 PM
The plans with data are for 30 days...but the option with data have no limit date...that's the difference...
02-21-2019 04:37 PM
02-21-2019 04:34 PM
02-16-2019 04:04 PM
@orahman wrote:Will I be charged data overage charges or will data stop working after my allotted data usage is used up ? Please advise.
Public Mobile is a prepaid service, so there's no such thing as overage or unexpected charges. When you've used up the data you purchased it just stops. One downside : If you run out too early in your service cycle, you'll have to wait for your next renewal date, or purchase an add-on.
02-16-2019 03:58 PM
Your data will stop after you have used up what comes with your plan. You can purchase data add-ons but there will never be any surprise overage charges with PM, If you haven't pre-paid for it you don't have it
02-16-2019 03:58 PM
Once used the data simply stops. No overages.
02-16-2019 03:58 PM
There are no overage charges and your internet access will just stop once you reach the limit.
