Data on plan renewal
Moon3
My data shows that it reset but it doesn’t work?
2 REPLIES 2
hi @Moon3
try reboot phone and then click Reset network settings
and make sure you do not have any Mobile Data Limit set on the phone
Sansan
Did you restart your phone?
If that doesn't work,  you can also reset networks.
