01-18-2020 11:51 AM - edited 01-05-2022 09:04 AM
I have a hauwei p30 lite, set up the apn settings according to the instructions, but my but it does not send or receive MMS messages
01-18-2020 04:13 PM - edited 01-18-2020 04:19 PM
@CannonFodder wrote:
@computergeek541 wrote:
@CannonFodder wrote:@annronreimer Is the FULL model name/number of that phone, by any chance, this one:
Huawei P30 Lite Dual SIM TD-LTE JP 128GB MAR-LX2J
There are, apparently, 5 different variants of that phone, and that particular one isn't fully compatible with all the bands needed for PM.
I'll assume that calls and texts work with this phone, and since the issue is only with data, the data not working isn't because of frequency band compatibility. All services including talk, text, and data are all possible over the HSPA+ network.
There's a screenshot posted by the OP earlier showing a connection to the Public Mobile network. Regardless whether that's a connection to either HSPA or LTE, data works on both at Public.
So, if that's the case, would the OP be getting HSPA on this?(assuming it was the variant I mentioned):
Coontext for your picture?
Public Mobile does not support 2G/GSM frequencies at all. Only Rogers (and its affiliates) does so until end of this year, I think.
For a phone to work on Public Mobile it needs a minimumg of 3G frequencies B2 (1900) and B5 (850).
For maximum data experience the phone needs LTE bands B4 (1700/2100), B7 (2600), B12/13/17 (700) as well as B2 LTE and B5 LTE.
01-18-2020 03:49 PM
01-18-2020 03:22 PM - edited 01-18-2020 03:26 PM
01-18-2020 02:20 PM
Try rebooting phone and turn on mobile data to send MMS messages. MMS does not consume data.
01-18-2020 02:06 PM
@annronreimer If convenient, try the SIM in another phone or a different SIM in your phone. You could also try going to a kiosk/store to try a test PM SIM and see if it works
01-18-2020 01:27 PM - edited 01-18-2020 01:28 PM
@annronreimer That screenshot is not complete it's missing the APN type info. Make sure the APN Type field contains mms. If not then add it at the end:
,mms
01-18-2020 01:27 PM
Have you tried to reboot your phone ?
01-18-2020 12:42 PM
01-18-2020 12:35 PM
01-18-2020 12:31 PM
Yes
01-18-2020 12:07 PM
@annronreimer Post a screenshot of your apn settings.
01-18-2020 12:06 PM
@annronreimerHave you enabled data in the phone settings?
