Data not working
10-22-2019 03:52 PM - edited 01-05-2022 07:41 AM
10-22-2019 07:50 PM
@Michaelmlyn wrote:my data sady its on but there is no internet connection. Help me please
Are you a new customer? Has data ever worked? If not compare APN settings to the ones from the following thred:
10-22-2019 04:01 PM
First item is to confirm you do indeed have data remaining. Login to your account (but you may have a problem with that ) and look under Data & add-ons; if you do not see a data plan there it has been completely used.
UNLESS, your plan just renewed and the data plan was not reset.
