04-03-2018 07:22 AM - edited 01-04-2022 03:50 PM
04-03-2018 11:44 AM
@andreaamadowrote:I just used half of my data.
You really should send the moderator team a message as @Mary_M (a member of said team and PM employee) suggested.
With as little of information we have here there are still several things that could have happened here.
- If you are on a 3G speed plan there have been reports that the data bucket has not renewed on the renewal date. Mods would need to confirm and fix this.
- You have apps in the background that are eating up your data - turn off background data, updates over data and, if you are on iOS, turn WiFi assist off. If that is what has happened, reread @mimmo's post. For an early renewal you also need moderator assistance.
Use this link to send a private message to the @Moderator_Team, include all relevant information in your message, such as account number, phone number, PIN*, detailed problem description.
More information on contacting the mods: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
*If you don't have your PIN you need to provide them with any 3 of the following items for identification:
- Complete mailing address
- Email address
- Alternate phone number
- Date of birth
- Last top up date & amount
04-03-2018 11:26 AM
04-03-2018 10:21 AM
If you have used all your data you will have a choice of:
1) buying a data addon 1gb for 30$
2) going without data
3) asking mods to renew your current plan early (add funds equaling your plan)
4) doing a immidate plan change to a plan with more data
options 2 and 4 are often batter value /gb than option 1
04-03-2018 08:54 AM
Good morning @andreaamado,
thank you for taking the time to reach out to us regarding your data usage !
To check your usage, login to your account, look under Account Status and click View Usage. If your data has recently stopped working and you're no longer able to view the usage on your account, there's a high possibility that you have fully consumed your allocate amount for the current period. Nevertheless, we can look into this for you - simply send us a private message 🙂
I hope this helps,
Mary
