Data not working
Katievry1
I switched to a new data plan yesterday and my data has not worked since. Cellular is still working normally. I tried everything the chatbot said. So fard no luck.
CSA_PM
Customer Support Agent
@ Katievry1
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Katievry1 you will need to ask PM CS agent to re-provision your account.  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Ticket", click "Contact Us"  then choose a topic, click "Login", finally click "Click here to submit a ticket ↗"
    (if unable to receive 2FA via SMS when login, click "Didn't Receive code" or "Resend Code")
     then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
@Katievry1
Try a couple things:
- Enable Airplane Mode then disable.
- Reset the Network settings on your phone.
