3 weeks ago
I have a PM plan with data and I’m not near the limit, when I try to use the data on 2 bars of service it doesn’t work. Is 2 bars of service generally not enough for data to work properly? Is the an issue with PM specifically? Or is this an issue on my end?
3 weeks ago
@BKNS27 wrote:2 bars means that you have weak signal and you are too far away from a tower or there are walls blocking a stronger signal.
Check to if signal is stronger outside. This is common with 5G so switch to 4G/LTE and see if that is better.
Having 2 bars only means that the current connection is less than ideal. It doesn't mean that there isn't a stronger signal available in that same location. It's entirely possible to have less bars but for that connection to provide better service, especially when it comes to speeds and network capacity. The phone will change connections automatically as needed.
3 weeks ago
3 weeks ago
hi @Blimpy
2 bars are more than enough
make sure you don't have data limit enabled
and try Reboot phone then click Reset Network Settings
3 weeks ago
I notice that it might take longer to download anything with only 2 bars available. If you want to download music or stream vids...it may not work until you get more bars.
