Data not working?
Karyathena1
I've had my data not work in an urban city of 150000 people. It's happened twice in two days. I've never seen this except when I'm camping in very rural areas.
Any ideas why this is happening? Thanks!!
2 REPLIES 2
hi @Karyathena1
reboot the phone and reset network settings
check MY account for account status
or ask PM support to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
Chalupa_Batman
You can try doing a network reset that forces your phone reconnect to the PM Network. If that doesn't work, you can reach out to a CS Agent as there have been reports of data issues today.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
