Data not working
Spenz
Hi there I signed up and activated my sim card for my android media box. The problem is the data doesn't work when I insert the sim card into. It has full service but data is not working. Yet if I insert sim card into my iPhone it works? I subbed to the 50gb unlimited plan.
Any help is greatly appreciated.
Thanks
2 REPLIES 2
Spenz
Thank you so much
@Spenz
your Android media box has a sim slot??
 Data is an APN issue.  Check the settings in the box and add the APN as below, case sensitive and please no extra spaces
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
