Data not working
Rafkem
I recently upgraded my data plan and I have not been able to use my mobile data since then. I have tried generating a ticket several times to no avail.
What's the way forward please?
Rafkem
Thank you HALIMACS! Rebooting helped.
@Rafkem
Try rebooting your phone by powering off then back on.
If that didn’t work, just DM a CS_Agent to investigate the issue and get you running.
HALIMACS
Try rebooting your device and resetting network connections @Rafkem
Otherwise, reach out to support for help.  To do that, forget the Chatbot, use the method below to reach them, which is via private messaging on the Community site.
To contact a Customer Support Agent, send a private message to them by clicking here.  You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
