Data not working
Alnoor1
Hi my data is not working. I had travelled abroad and changed my SIM card. I did all the steps mentioned by community to turn airplane mode on and off, reseat SIM card and finally reset network settings. Still data does not work. Any other suggestions?
Alnoor1
Thanks for suggestion I went to vpn screen and there are no profiles.
@Alnoor1
a common issue with data after using travel sim is the VPN.  check your VPN screen and delete all VPN profiles.
Then reboot and  click Reset all networks and test
@Alnoor1  reset your APN settings
