09-13-2018 06:34 PM - edited 01-05-2022 05:40 AM
Data has not been working properly for some time on my OnePlus 3T. Today I put in another PM SIM and it connected right away. And my SIM in the other phone also did not work.
The account has 6 GB data enabled (90 days), and NO data has been used this period.
I did see that there have been some attempts to connect to data in the usage history, showing 0 MB data a few times.
The APN settings have been changed to match exactly with 2 other PM phones that are working with data. As well as trying to match up with what a number of posts and websites indicate the APN should be, such as here
https://apn-canada.gishan.net/en/apn/public-mobile/oneplus-3t
09-14-2018 05:16 PM
Thanks for everyones help so far. But I think this might be something for @CS_Agent
09-14-2018 05:03 PM
I have already tried network resetting. I even went so far as to completely reset my phone. Blanked it out and started from scratch. Painful, and it did not help.
09-14-2018 05:01 PM
My plan includes data as shown without being an add-on. So "My Data and Add-ons" has nothing in it. My plan is obviously active as I can talk and text, and it says the plan is active.
09-14-2018 04:55 PM
Yes, it was working for a long time. I did have a problem after an update of the OS, but I got that resolved. Then data worked again for a while and stopped.
09-14-2018 12:14 PM
@ash195541 wrote:sometimes you have to download a certain extension to your phone settings i remember having this issue once with chatr where i purchased a data add on and it wouldnt work so i called them and they gave me a certain link to go to and than i had to download it to my iphone from the webpage, the reason this happens is cause the provider you were with before already had theese settings put into your phone from purchase so you dont have to deal with it from the get go until you switch your provider. contact the modrator team and see if this might be the case, to contact the moderator simply go to your messages and compose a mesage addressed to Moderater_Team or tag them in your community post @CS_Agent just as so
@ash195541 this.....doesn't sound right.
@ThomasR I agree with @mimmo, it sounds like you might have a back-end issue rather than a phone or APN issue. You could try a network reset [settings -> Backup & reset -> Network settings reset -> Reset settings button] first to see if that helps.
09-13-2018 08:32 PM
09-13-2018 08:09 PM
I would send a message to mods and ask them to look into 'reseting" your account to make sure there is nothing on the systems end. Also link to this thread or explain all the steps you have done.
09-13-2018 06:46 PM
In your account under "data and Add-Ons" does it show as active?
09-13-2018 06:40 PM
@ThomasR wrote:Data has not been working properly for some time on my OnePlus 3T. Today I put in another PM SIM and it connected right away. And my SIM in the other phone also did not work.
So are you saying that it was working properly and then it stopped working properly?
BTW, Good troubleshooting by switching sims!
