Data not working after set up new eSIM
Durst23
Just transferred a number with a new eSIM and now my data isn’t working
@Durst23
voice and text both work and just data does not work? or nothing working at ll?
still try to Reset Networks settings on your phone , and make sure you have Carrier Profile updated.  Of course, better to update iOS as well
@Durst23
Do a force reboot on your iPhone 11 Pro Max. Push volume up, volume down, hold power button then slide to right to power off and power back on.
Durst23
My phone doesn’t give option to change apn settings
Durst23
iPhone 11 promax
@Durst23
voice and text work?  if they both work, it is a problem with APN.  What's brand of phone is that?
you can start with the easy fix: Reset All Networks and see if data starts working
if not, then compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
