07-13-2017 11:38 PM - edited 01-05-2022 02:26 AM
i have the 12gb 90 day plan. I travelled to the US and had a roaming add-on for my trip. After returning to Canada, my add-on expired and now my iPhone shows a cellular connection, but any attempts to use cellular data time out. The phone works fine on wifi. I've rebooted the phone, but no change.
How can I check my data usage total in my profile? I've checked in my overview and add-on areas but it's not mentioned. When I check each page of my usage history, its well below 12GB from what I can manually add up.
What gives? How can I get my data flowing again?
Thanks in advance!
07-14-2017 11:38 AM
@chozobee it's at least possible that you've used up all your plan data, though I know you said you added up the history numbers manually and didn't think you were close. The amount disappearing from the My Add-ons section *usually* indicates you've used up the data, which is a horrible design decision flaw in my opinion, and I've been asking PM to fix this for ages with no results.
Try sending a private message to @CS_Agent for assistance.
07-14-2017 09:49 AM
I've done both, and no change. This is what I see in the overview page:
http://i.imgur.com/mIs2275.png
Who is the mod to message?
Thanks!
07-14-2017 12:13 AM - edited 07-14-2017 12:21 AM
