Data issue
11-14-2021 07:27 AM - edited 01-04-2022 05:12 AM
11-14-2021 01:04 PM - edited 11-14-2021 01:04 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
11-14-2021 10:37 AM - edited 11-14-2021 10:38 AM
@singhrajinder does it just start not working today?
What kind of plan do you have? Did you login to My Account and confirm if you still have data remaining for this cycle?
did you try reboot your phone? Did you try different app to confirm the data access?
Are you on Android? If so, Android has a monthly data limit setting, any chance you have used that and limit reached?
do you have a second phone around you can try to confirm it is not a device issue?
11-14-2021 09:28 AM
Check your APN settings. Try rebooting your phone.
11-14-2021 08:32 AM - edited 11-14-2021 08:33 AM
Sign in to your self serve account and look under the data and add-on section.
It will indicate whether you still have data remaining in your current cycle.
If you do have data remaining, try manually selecting 3G under network settings. Now, try your data again.
11-14-2021 07:38 AM - edited 11-14-2021 07:39 AM
@singhrajinder wrote:I’m in Edmonton, data is not working here
Hello @singhrajinder
Did it work for you previously with no issues?
EDIT :What about all your other services...calling/ texting?
Check for outages in your area: https://www.telus.com/en/on/outages
or https://downdetector.ca/status/telus/map/
Try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
