01-30-2017 04:50 PM - edited 01-05-2022 01:39 AM
Just port in from virgin mobile at 3:20pm today, phone call is working now, but data is not, please help.
Service
01-30-2017 11:20 PM
Try restarting your handset sometimes that can correct the data issue.
01-30-2017 10:19 PM
Working very well now when I create a new apn. Thank you guys
01-30-2017 07:45 PM
@crazycolby here's another silly question: are you sure you have mobile data enabled on your phone? On most Android phones it's easy to disable it by accident by tapping on the mobile network icon in your quick toggles on the notification pane. I've done this a few times and felt silly when I figured it out a few mins of wonder.
01-30-2017 07:42 PM
Data and porting are unrelated so please disregard anyone that's mentioned a porting issue.
What EXACT model of Huaweui phone do you have, @crazycolby? Be as specific as posssible.
01-30-2017 07:24 PM
If you can text/call, then it's most likely your APN Settings, so you need to update that
01-30-2017 06:14 PM
01-30-2017 06:04 PM
try using a new apn instead of editing.
dumb question but self serve shows you have data addon? and it shows that it is 0ish/?gig????
01-30-2017 05:58 PM - edited 01-30-2017 06:02 PM
01-30-2017 05:53 PM
What phone are you using? some phones LG G5 I think require a factory reset. did you create a new apn or edit an existing one?
01-30-2017 05:36 PM
01-30-2017 05:26 PM
Looks like you have a porting problem. You'll need to private message a moderator with your account phone number.
01-30-2017 05:21 PM
Tried APN and still not working. thank you
01-30-2017 04:59 PM
01-30-2017 04:54 PM
Porting usually takes a couple of hours to complete. I advise to give it a bit more time.
In the meantime, check your APN settings and reboot your phone:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
If it still doesn't work by this evening, then it may be a porting error. Then you'll need a moderator's help to fix it:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Contacting-our-Community-Moderators/ta-...
