Data doesn’t work
Caylee
I recently changed my phone plan with Public Mobile and since then My data does not work and my phone number comes up as unknown. Everything worked fine before the plan change. I have done every recommendation on chatbot but it still doesn’t work. I tried sending help tickets but it gives me an error and won’t accept my help ticket request. I am basically giving you my money right now for a service I am not receiving
8 REPLIES 8
Caylee
The first one was an XR iphone and the one that the sim is in now is a brand new iphone 15
 @Caylee
what phones did you try. Android or iPhone??
try Reset All Networks or Reset Network Settings and that can help to get the data up and running quickly
@Caylee  Sounds like an account issues please submit ticket with support to help
send  a  private message   To CS_Agents
Caylee
Calls work and sometimes text, but no data.  Put sim in a brand new unlocked phone and still no data.
Momomomomo
@Caylee only data doesn't work? Or no calls either?
Caylee
I have tried that and every other suggestion and nothing works
Hollister
@Caylee
Have you tried resetting network settings, reinstalling SIM card, tried sim in another unlocked phone?
  • you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 9 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
@Caylee  Might be a APN issue , but to contact support the chat bot is broken . You can use this direct link to support
send a  private message   To CS_Agents click
