Data completely stopped working
Jaygre9
Woke up this morning data completely stopped working. Reset iPhone, reset network settings, checked billing no issues, checked data usage no issues, did the above 5 times each. Still not working. Airplane mode on and off. Still not working. This is the most infuriating and frustrating experience I’ve ever had with a carrier. There’s literally not solutions
edited by computergeek541:  changed category labels as this discussion isn't related to My Account/self serve account
CSA_PM
Customer Support Agent
Hello @ Jaygre9,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Jaygre9
No, greater Toronto area I live in the gta.
hi @Jaygre9
are you in Oshawa or Ottawa?
hi @Jaygre9
since you already tried reset network settings, you probably need PM to refresh the account.
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
maybe outage?
https://www.telus.com/en/bc/outages
and ask PM to help, Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
