Data bundle Recharge
Izuchukwu
How Can I top my data bundle. My days bundle finished before time.
@Polution
It should be in your account the Add-ons section.
@Izuchukwu
Login to your account and pick the data-on you wish to purchase.
The only bundle plan is for USA Roaming.
Not sure if this is what you are looking for.
@Izuchukwu   are you talking about you regular data from your monthly plan?  you have couple choice:
1.  buy 1GB addon for $15 on My Account yourself
2. ask for early renewal of your plan with the help of PM Support.  You have to open ticket with them :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
3.  Make a plan change and select "Change plan now" on My Account.  With this option, you can only change to a different plan from what you have now
dust2dust
You can buy a different bucket of data. You can't buy the same one when it's still active (even though depleted).
