07-14-2025
02:47 PM
07-15-2025
12:20 AM
computergeek541
How does Data usage work? When I look at usage breakdown the times showing that I used data are overnight when I am sleeping, not on phone using data. And most times when I could actually be on the phone I would be connected to the internet at home so shouldn't be using data. I am confused.
Thank You to anyone who can "unconfused" me.
07-14-2025 02:49 PM
hi @Junebug3
the usage you see is the total usage of the day. PM usually posts them in 1 or 2 entries daily , usually shortly after midnight
so, no worries, it didn't mean all data were use in that time
07-14-2025 02:48 PM - edited 07-14-2025 02:49 PM
@Junebug3 The usage is only updated 2x a day so your only ever seeing the past 12 hours used it’s not real time usage
edit also note that if you have wifi assist on in phone settings it can still use plan data even when on wifi example like being in garage and having weak signal
