Data Plan not working
summy99
Hello, I have a ASUS Zenfone and everything works perfectly except for the data plan. I switched sims into another phone and have the same problem. Please let me know what  I should do.
2 REPLIES 2
summy99
thank you so much that totally worked!
@will13am wrote:
@summy99, from what I recall, manual APN entry was required for the zenfone at least for the model I used to use.  Here is a legacy thread on how to set up the APN which is still applicable today.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
will13am
