Data Only Plan
BDW
I see under PLANS there is a $30 Data only plan.
Would this work for an iPad?
BDW
Thank you!
popping
Yes.  The $30 1GB data only plan is full LTE speed.
If you don't need full LTE speed, your can get the LTE paln capped at 3Mbps with more data.  Any PM data plan will work with a LTE iPad with a SIM card slot..
Triguy
Data should work on your ipad as long as you setup the PM APN settings.
https://support.apple.com/en-us/HT201699
hss
Yes it would.
