Data Not Working in USA
JF5
Hello. Just wondering if anyone would know, if you are travelling in the USA and purchased an Add On, USA Roaming, Talk & Text, would the Data on your plan work in the USA or would you have to purchase additional Data specifically for the USA to your Add On ?
Thank you for any input or suggestions.
J
JF5
Yes I know you need USA Roaming but it was the Data Add on to access Data if you have no Wifi access. I have 4G and Data on my plan but was unable to access any Data. So glad when they changed their Add On Plans from 10 days to 15 days. Makes more sense. Thanks for your input.
@JF5
Yes you need USA Roaming to connect to T-Mobile Network while in the USA.
Add-on roaming recently changed from 10 days to 15 days.
Rates varies depending on what you need. Just login to account and go to Plans & Add-on section for rates.
@JF5  You need data roaming for the US
