Data Issues
Suraiyamathias
For the past month my data has been super slow and barely loads anything? I am not sure why since I don’t have it on for a lot  of things. Has the data at public mobile changed recently or has anyone else been experiencing this ?
would love for some help on this as I don’t want to switch providers.
@Suraiyamathias   You don't need a new SIM, especially if @esjliv  suggestions has fixed the issue for you.  As to slow speed with the data, quite a few other customers have also mentioned that over the last few weeks.
Suraiyamathias
@esjliv @Hi!! Thank you, this seemed to do the trick. I just saw online on publics site that the distribution network changed — would this mean I need a new sim? I suck at this phone stuff lol.
thank you!
@Suraiyamathias - hard to know if this is a device or account/sim or tower/network issue without some troubleshooting.
Try 1 or more of the below:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • move your sim card to another phone to see if services are improved
Perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
Alexandf
@Suraiyamathias
reset network and set APN setting,
still not works, open ticket with PM support and ask them to check it for you.
 At https://publicmobile.ca/chatbot.
have trouble with Chatbot: private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
