Data Connection + LTE vs Voice Call Quality
NuYearNuMobile
I dont use data on my phone.
So I have Data Connection> Off
But beause of the above, LTE next to signal bar also disappears.
I have heard that some networks use VOLTE.
I was wondering if LTE has any effect on the quality of my voice calls.
If yes then dont mind turning on the data.
NuYearNuMobile
Just to confirm, as of now voice call on PM will be purely on 3G.
mimmo
Just a FYI, mms require a  data connection, even if you don't have a data plan.  So turning off data will disa le your ability to receive send mms.
PM probably wont have volte anytime soon.
Maybe their bigger pier brand would have it.
NDesai
@NuYearNuMobile VoLTE is not available on PM. LTE symbol will disappear when you have data turned off. So when you are on a call, it will always route through 3g network.
