04-05-2019 07:30 PM - edited 01-05-2022 04:11 AM
Hi all, I am brand-new to Public Mobile, having just ordered myself a gorgeous new Xiaomi Mi 9, ("global" version) and having ordered my SIM card moments ago. I have been assured by the retailer that this phone will indeed fully work on every Canadian carrier with the exception of Freedom Mobile, but I'm curious to know if anyone else on here might have the global version of this new phone, and if so, how is it working for you?
Thanking you in advance,
Glen B.
04-07-2019 01:43 PM
Computergeek541, I should be good to go then, because this phone indeed has all of the frequencies you mentioned. When my phone arrives next week I will report back to let you all know how I am making out!
Thanks,
Glen
04-06-2019 05:16 PM
If your new phone is unlocked and compatible with Telus networks it iswill mostly likely work with public mobile as well.
04-06-2019 12:50 PM
@camperbc wrote:will13am, here is a list of the (Global) Xiaomi Mi 9's supported network bands:
4G: LTE FDD: B1/2/3/4/5/7/8/12/20/28
LTE TDD: B38/B39/B40
3G: WCDMA: B1/B2/B4/B5/B8
TDSCDMA: B34/B39
CDMA EVDO BC0
2G: GSM: B2/B3/B5/B8
CDMA 1X: BC0
Supports 4x4 MIMO | HPUE | HO RxD
So, I'm assuming that the listed 4G: LTE FDD: B4, and 3G: WCDMA: B4 are the bands you are referring to?
Thanks,
Glen B.
The most important thing is not LTE compatibility. The first thing you should be looking at is the 3g/WCDMA/HSPA frequencies. Make sure your phone has 850 and/or 1900MHz (Bands 5 and 2) for WCDMA or you won't be able to make or receive any phone calls. Data services can also be used over WCDMA. LTE compatibility is optional.
04-06-2019 04:27 AM
TDSCDMA: B34/B39
CDMA EVDO BC0
CDMA 1X: BC0
Thanks,
Glen B.
04-06-2019 12:49 AM
@camperbc wrote:Sunflowershine, I admittedly know practically zilch about this technical mumbo-jumbo. As I don't yet have the new phone shipped to me, I am unsure if it's compatible with these numbers. Pardon my lack of knowledge, but does my new phone have to be compatible with all 7 of these frequencies? Or just some of them? Or...?
Sorry, but as this is my first new cellphone in years, I still have SO much to learn... Thanks again for your kind assistance; very much appreciated!
Glen B.
I more supported bands the phone has, the greater the compatibility. Some bands have greater coverage on the network. Band 4 is probably the widest coverage. If this is available on the phone, it should be fine.
04-05-2019 08:03 PM
Glen B.
If this is what you purchased, then you are covered with all frequencies 🙂
04-05-2019 07:57 PM
Glen B.
04-05-2019 07:40 PM
As long as the phone is under the frequency, it should be fine.
04-05-2019 07:35 PM - edited 04-05-2019 07:36 PM
Looking at the specs of that phone, it looks like it supports mostly all bands required on the Telus network. So you should not have any problem using this phone on PM.
