07-05-2020 09:06 PM - edited 01-05-2022 11:59 AM
I just added 1 GB of data to my account, but don't see it showing up under Add-Ons?
Is there a delay?
07-05-2020 09:11 PM - edited 07-05-2020 09:12 PM
@HTime wrote:I just added 1 GB of data to my account, but don't see it showing up under Add-Ons?
Is there a delay?
Sounds like you did step 1. Go back and "buy " it again. It's a little non-intuitive. You need to add money first then buy add-ons with that added money.
Edit: dang
07-05-2020 09:11 PM
Buying an add-on is a two-step process. Are you sure that you 1) added funds to your account AND 2) used those funds to purchase your add-on? Does it show up as an active add-on in self-serve?
07-05-2020 09:11 PM - edited 07-05-2020 09:11 PM
Is there a delay?
Nope...should be usable right away. Look at Available Funds...do you see your payment for the add-on there. Now go back to Purchase Add-ons and select the one you want.
