Customer service
AllT
Hi does customer service agents work on weekends?   Thanks
OlivierR
Yes they work everyday from 9am to 10pm in the UTC -5 timezone!
Chalupa_Batman
Hi @AllT
To submit a ticket, start with the chatbot at the bottom right corner.
Or the following link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
May I ask what the issue is? Maybe we can help.
HI @AllT
yes they do
you can submit them a ticket or you can also share your question here and community will try to help
 To submit a ticket with CS Agent,  use this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
