07-14-2021 08:09 PM - edited 01-06-2022 03:01 AM
I was thinking about changing my phone number and when I went to change my phone number through my account, only a small number of new phone number choices show up. I refresh the list and the same numbers show up. Is there a way to either view more new phone number choices or is there a way to pick a custom number of my choice?
Service
07-24-2021 10:09 PM
Some custom numbers are for sale on Craigslist.
Also check voip services with a better selection and do a port. May cost a few dollars. Look at Fongo or VOIP.ms.
07-17-2021 02:37 PM - edited 07-24-2021 10:33 PM
@Anonymous wrote:Changing Your Number After Activation
You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account Here and:
- Select the “Plans and Add ons” tab
- Click on “Change Phone Number”
- Then, you can choose to select a new phone number
Good Luck
In this case, the customer RSS2021 aready knows how to change the phone number. The question was about how to get a better selection of phone numbers. Customer used to be able to search for the last 4 digits upon activation. Unfotunately, that option is no longer available. In addition to that, that option was never made available to existing customers.
07-17-2021 01:33 PM - edited 07-17-2021 01:34 PM
Good Luck
07-17-2021 01:12 PM
Which city are you in? Some areas like the BC lower mainland have a half dozen cities/exchanges that are all traditionally local to each other -ie Richmond, Bowen Island, Vancouver, New Westminster, Aldergrove...Maybe your area has similar flexibility.
You can also check number inventory at places like numberbarn.com that specialize in porting out numbers.
07-14-2021 08:22 PM
Thanks! I will try that.
07-14-2021 08:18 PM - edited 07-14-2021 08:18 PM
You can't really pick a number of your choice, but one "trick" people have found is to select a different city, then select yours again. You'll generally see more/different phone numbers populate but that's just about the only way to see a different number.
Another way to get the "phone number you want" is to have it elsewhere, then port it into Public Mobile.
