Credit Card not accepted
gelmac
My credit card expires in 2025. This option is not available in the drop-down list when adding a credit card. Can you fix this please!
Riettarose
Contact the moderators, the more they hear about this problem the more likely they are to fix it.
CMOADMIN
I am going to go out on a limb and say this is an administrator task and moderator(s) would not have access to such aspects of the domain.
Triguy
There was a thread about this issue.  You would need to contact a moderator. https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Expiry-date-on-Public-Mobile-...
ChuckYeah
I guess this is another challenge with the automated system, it will likely require another tiny system update. @CS_Agent
Jackhyf63
@gelmac
In this case may be Mods might have the ability to manually add cc with longer expiry date.
