Credit Card cannot be verified.
mjat87
My last payment was made with a Mastercard gift card. I am now trying to re-add my actual credit card for autopayment. I also urgently need to add roaming service to my account. Unfortunately, I am unable to do either, as I am encountering a message which says "we are unable to verify your credit card information".
My credit card is working just fine. I am currently calling them to verify that all is well, but I have successfully been using the card all week long.
How can I get a hold of a moderater to look into this for me?
Thanks.
11 REPLIES 11
Try removing and add back your credit card.
 If you are using a payment card, leave the apartment/suite number in the payment information section blank.
Karyathena
Spoiler
Hi there,
my credit card is doing same thing , moderators want all my credit card information including phone number on card, etc. Did you have to do this?  I’m uncomfortable sending all this information. Card has worked for a year , no hold on card etc. Just wondering what your solution was
thanks!
iPhoneUser
I have usually had help and resolutions with in 4-5 hours.  Just get on it!
@mjat87  moderators response time varies from 24 / 48 hours. You may want to consider a top up voucher for this time for your add-on.
mjat87
Okay. Thanks again all for the help and suggestions. I've message the mod team and hoping to hear back asap.
I understand the payment voucher options better now, thanks.
-Matt
hycm53
Thanks.
When you add new credit card, make sure name on the card, card number, address on the credit card statement is accuately.
@mjat87 have you tried using 611 from your phone?  Here's a link to guide you https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352/highlight/t...
@mjat87 wrote:
Thanks for the replies.
I'm not interested in purchasing a prepaid credit card right now, though I appreciate the suggestion as a work-around for now.
I just confirmed with my Credit Card company that there are no restrictions on my card--there is nothing on their end that should prevent Public Mobile from authorizing the payment.
And yet, I am unable to either make a one-time payment for roaming package on my card, or setup the card for autopay. I recieve the "cannot be verified" error in both scenarios.
To be clear, I have always used this exact same card for autopay. I removed it only for last month so that I could make use of a gift card which I had. Now I cannot re-add my credit card!!
The issue for me right now is that I *need* a roaming package for my phone like *right now*, and I am unable to make it happen. The 2-3 day window for moderator reply isn't very encouraging on that front, but I will message them regardless.
@mjat87  we understand you need a addon right now.
Only moderators can look into your credit card issue (if you have a apartment number as mentioned above leave that section blank) if nothing works you need moderators to look into your credit card issue.
Now as you need a add-on right now. You have two options...
1-..go to a gas station, corner store and buy a top up voucher.
2-. Go to recharge.com website and buy a voucher. You can pay with your credit card , they even take Paypal.
mjat87
Jb456
Have you considered purchasing a voucher? You can get them at places like Petro Canada , esso, shell, corner stores
You can also try recharge.com to buy a top up while you get your credit card sorted.
For moderators
Or private message at link below.
https://productioncommunity.publicmobile.ca/t5/Rewards/Contacting-mods/m-p/409071#M9218
Jb456
