07-27-2020 09:45 PM - edited 01-05-2022 12:17 PM
Does public have a couple plan? My friend and her spouse would like to switch to public and wonder if it has a couple plan for them.
07-28-2020 12:16 PM
Unfortunately there is no couple plan currently available. Each phone requires a SIM card and unique Phone number. I would recommend: One of the members of the couple can sign up first, and share their promo code with the other member of the couple and receive discounts that way.
07-28-2020 08:51 AM
@mh1983 You seem surprised! LOL
07-28-2020 08:36 AM
Half a dozen posts w/ the same response!
07-28-2020 04:33 AM
No couple plans but one can refer the other and benefit from the refer a friend reward. The partner with the higher data needs can take a larger plan and hot spot the data from their plan to their partner if its needed or outgoing calling........ for example if one partner takes the $50/8.5gb plan with US calling on top of unlimited canada wide calling and the other partner takes the $15 plan w/250mb and 100 outgoing minutes by sharing their phones when calling needs to be done and share data thru a hotspot while waiting for a ferry ....plus it keeps them close together! They can upgrade or downgrade their plans
07-28-2020 01:20 AM
@trinhnp If they are interested in a couple plan so that they can share data unfortunately that is not available.
07-27-2020 11:35 PM
@trinhnp wrote:Does public have a couple plan? My friend and her spouse would like to switch to public and wonder if it has a couple plan for them.
Tell them that it would be two separate accounts but they can be paid automatically by the same credit card. I am sure they can find 2 plans with more data for cheaper than they would a family share plan
07-27-2020 10:26 PM
@trinhnp Not at the moment unfortunately. No couple plan and no family plan. Only separate. But you can use the same CC to pay for plans.
07-27-2020 09:55 PM
Sorry no
But really good deals, beat most of family/couple/group deals
07-27-2020 09:48 PM
No. One SIM, one number, one email address, one account.
Couple plan...how sweet 🙂
