06-20-2022 02:23 PM
Hi,
I have purchased a US Roaming Package (20$). While in the US the phone showed me connected to T-Mobile, but I could not send an SMS or originate a call and had no data. I want this transaction to be canceled as I was never able to use it,
TIA
06-20-2022 09:34 PM
@dravin did you tried to connect to T-Mobile as well?
Also, you have loaded the fund as well as use the fund to buy roaming add-on? It's a 2 steps process
But you have never use it and unable to use it , try to open a ticket with PM Support and maybe they will agree to reverse the transaction and put the money back to your account for use in your next renewal.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-20-2022 09:21 PM
Did you have Roaming turned on?
06-20-2022 06:28 PM
Connecting to T-Mobile or AT&T is done correctly but to purchase any Roaming plan, it is a 2 step process.
1 - Add the amount of the Roaming plan to your account.
2 - Make the purchase of the Roaming plan
then double check to see if the Roaming plan is listed on your My Plan & Add-ons
section.
If both steps were done then contact a CS_Agent to get a refund.
06-20-2022 02:35 PM
Do you still have at least $20 in your balance? If so then you didn't actually complete the purchase. If not then as above.
06-20-2022 02:29 PM
you will need to open a ticket to speak to a customer service agent they will help you Click here or you can send private message to a CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
