Could I replace my current cell phone number with my home phone number? and How do I go about it??
03-31-2015 09:10 PM - edited 01-04-2022 01:18 PM
04-01-2015 12:42 AM
03-31-2015 09:53 PM - edited 04-01-2015 08:59 AM
Hello @HM,
Yes, it's possible. You have to port your landline number to Public Mobile.
You can verify on the self serve if your number is eligible to be transfered or not.
Direct link from the self serve is :
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/msisdn-swap/
Click on "Transfer a wireless or wireline number from Public Mobile or another provider"
Then, under "Check to see if your phone number is eligible", enter your phone number.
Important : the number you want to transfer toward Public Mobile must be active (bill paid) while you're doing the transfer.
