Connecting
gtgwilt
I switched to public, checked that my phone was unlocked, and the payment has gone through. My phone indicates that the carrier is public, but I can’t connect to the network. It’s showing ‘SOS only’ can anyone help where it would show the network. Can anyone help?
8 REPLIES 8
TrevorF1980
They'll definitely help. It took longer than I wanted buy once they'd verified my account and confirmed the issue, the fix was fast.
It is really hard to do virtually and would be almost impossible without some level of comfort with tech. But that's also why PM is cheaper. And, I've been really happy with the coverage, usage, and speeds since I switched.
@gtgwilt wrote:
I think I’ve submitted a ticket, where do I look for that? And do they work on weekends?
@gtgwilt   if you messaged them, you can confirm it on your Sent box
https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage/tab/outbox
Also, monitor your inbox for PM's reply
@gtgwilt
Customer support agents are available every day of the year, inclusing weekends and holidays.
gtgwilt
gtgwilt
Thanks so much! It is a physical sim and I have a feeling this may be what’s happening. I entered the sim number when prompted but never did see, or missed, the prompt for when to insert the sim, so I completed the transfer and realized I hadn’t put it in. I put it in after the process was done - hope they can help. I must admit that doing all of this virtually without talking to a human is really hard.
TrevorF1980
This happened to me too and it was because I'd screwed up getting the esim activated. If you only activated recently, it's possible that the number porting is taking longer than usual. (Apparently, it can take up to 2 or 3 hours) I had to set up the esim manually via a qr code. If you're working with a physical Sim, and it was a while ago that you activated and ported your number, you'll probably need a ticket with customer service.
gtgwilt
Thank you! I will try all these.
@gtgwilt try  clicking Reset All Networks and see how it goes
Also, the phone used in another Network before? for peace of mind, check if phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
(f it is clean, and still not connect, open ticket with support
