Connecting an S20 FE
Helper2
Hi, my friend has a Samsung Galaxy S20 FE 5G , and we are wondering if he could go to Public Mobile. The website to check if it will have service doesn't include the S20.
@Helper2
Yes is will working with Public Mobile.
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
visit  Here link, to check it all Provider in Canada about your device...
 @Helper2 : If he already has it then yeah just try your SIM in it. Then give him your referral code for that nice referral gift.
Yes, S20 FE would work without issue., my friend is using it
(but make sure yours is a North American versoin)
Helper2
He did buy it in Canada, thanks.
 @Helper2 : If bought in Canada it should be fine. If from elsewhere then most likely fine. Try your SIM in it to test.
