09-22-2020 08:51 PM - edited 01-05-2022 01:18 PM
I ordered two PM SIM cards, one for myself and my mom, as new customers. I activated my mom’s SIM card and transferred her number from Freedom Mobile and her SIM was activated immediately in her iPhone - AND it works in my iPhone.
I then activated my SIM card and transferred my Freedom Mobile number, however my iPhone and my mom’s iPhone cannot detect my SIM card at all. When I put my old Freedom SIM back in, there’s no service, obviously indicating that the transfer was successful. How can I fix this? If getting another new SIM card is the solution, then I’d prefer for PM to send me a new one at no cost.
09-24-2020 09:57 AM
I'm glad you got it all worked out. Just respond to the moderators and ask for a $10 credit on your account.
Although not common bad sim cards do come about.....walmart had a whole batch of them awhile back.
09-23-2020 10:00 PM
Was it possible you had 2 accounts under one name, unless it was in face a bad SIM.
09-23-2020 03:09 PM
Bought a new PM SIM card today and it worked immediately. Will contact the moderators for a refund of the old one. Thanks!
09-23-2020 01:07 AM
You've done everything you can to see if the sim card will work. Follow @Jb456 suggestion and contact the moderators to try and reprovision your sim card. If they are unable to do this then it may be easier and faster for you to source a retailer in your area to purchase sim card. The moderators will then apply a credit to your account equal to your purchase price.
09-22-2020 09:12 PM - edited 09-22-2020 09:13 PM
@AB7 not truly a faulty sim as of yet. The system at sign up may have encountered a glitch and the sim card was not provisioned correctly. You'll have to reach out to moderators for them to look into.
09-22-2020 09:10 PM
Thanks for your suggestions! My status is active on my account and my correct phone number shows up under the plan tab.
I’ve rebooted my phone, turned it on and off, cleaned the SIM, blown into the little insertion place... When I insert the SIM my phone doesn’t respond to it at all. When I insert my mom’s SIM, the cell service bars respond immediately so it truly appears to be a faulty SIM.
09-22-2020 09:09 PM
if you go buy new SIM cards and Perform successful sim swaps. You can ask the moderator team for a refund on your Sim card
09-22-2020 09:05 PM - edited 09-22-2020 09:06 PM
Contact moderator's to have them look. The Sim card may not be provisioned correctly and they have to do something on their end to fix it.
Or via private message at this link
If you used a referral code on the accounts for a $10 signup bonus. It will be credited to your accounts within 72 hours.
Welcome to Public Mobile🙂
09-22-2020 09:04 PM
Hello @AB7 ,
What does it say on YOUR self serve account for your status?
Did you reboot your phone when you had YOUR SIM card in?
You can check with the moderators on YOUR account to make sure it was provisioned properly.
To contact the Moderator_Team, there are two ways to reach them:
1-Click the question mark on the bottom right hand side of your screen to talk to SIMon the chat bot.
https://publicmobile.ca.ada.support/chat/
OR
2-Contact the Moderator_Team via private message using this link.
