Compatible phones
cell1
Hi, I am looking at Samsung Galaxy phone. I can't seem to find very many that will work on P.M?
I'm looking at the A32 or A52 Galaxy models.
Will these work?
Thank you 😊
8 REPLIES 8
 @cell1 : Who said it doesn't work? One had some variation hesitation. If you can report the full model number then we could be sure. ie. SM-A325F/DS or whatever the heck.
@cell1
i have one friend he buy it from samsung canada  for galaxy A52
is working with public mobile 100% ...
cell1
Hi,
Thank you for the recommendation. Some say yes that it will work on public mobile but a couple have said no it won't work.
Thanks again!
@cell1
i suggest you to buy it a samsung galaxy A52
very nice device and the Resolution (Main Display)1080 x 2400 (FHD+)
and buy it from Samsung canada better visit Here
or if you like that one samsung galaxy A52
but the Resolution (Main Display)720 x 1600 (HD+) visit Here
@cell1  Both A32 and A52 will work on PM without issue
In fact, if you are getting new Samsung phone out there now, as long as you are getting North American models, they will all work on PM
ShawnC13
Will these work?
Thank you 😊
@cell1  a great site to check it www.willmyphonework.net.
There seems to be a few different models of the A32 do you have what bands it works on?  If you know it will work on Telus it will work with PM
@cell1
Yes will both working with public mobile 100%
