Compatible Phone list? International Samsung S9 Compatible?
alchemywander
Hi all,
Just wondering if I can buy a Samsung S9 international version and connect to the network.  Kinda poked around but didn't see anything with compatible models.  If it matters, I'm in Northern Ontario.
Thank you!
alchemywander
Yes, thank you. Shortly after posting I stumbled across the site and checked.
@alchemywander wrote:
Hi all,
Thank you!
What is the exact model number of the variant that you have?
Hi all,
Thank you!
Looking at willmyphonework.net for just the S9 seems to suggest they all should work.
Lieux
@alchemywander  a écrit :
Hi all,
Thank you!
Did you check on willmyphonework.com?
