11-30-2020 12:14 PM - edited 01-05-2022 04:18 PM
Is umudigi s5 pro compatible with public mobile, I can find the s3 pro but not the s5.
would like to know before buying the phone
Phones
11-30-2020 12:22 PM
@Helpershelper wrote:
Unfortunately it doesn't look like it's officially supported.
I strongly recommend using the tracker as an "official" determinant of compatibility. There are so many new brands and models out there, it is hard for the tracker to stay current. The best way to determine compatibility is to back to first principles. Identify the bands on the phone and compare against the operating bands on the Telus network.
11-30-2020 12:20 PM
11-30-2020 12:19 PM
This phone will work with Public mobile.
Here are the specs of the phone:
https://www.umidigi.com/page-umidigi_s5pro_specification.html
4G: FDD-LTE: B1 /2 /3 /4 /5 /7 /8 /12 /13 /17 /18 /19 /20 /25 /26 /28A /28B /66 /71
TDD-LTE: B34 /38 /39 /40 /41
3G: WCDMA: B1 /2 /4 /5 /6 /8
TD-SCDMA: B34 /39
CDMA EVDO: BC0 /BC1
Public mobile uses these bands
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS). band 12, band 5, band 2, band 1, band 4
- HSPA: 850 MHz, 1900 MHz (UMTS).
