Compatibility
10-22-2019 07:24 PM - edited 01-05-2022 07:41 AM
Can someone please tell me if the Samsung Galaxy J3 Prime phone is compatible.
Phones
11-05-2019 12:53 PM
Yes it should work but you can always double check on the website before you buy a SIM card 🙂
10-22-2019 07:28 PM
@Habarc1 wrote:Can someone please tell me if the Samsung Galaxy J3 Prime phone is compatible.
You can try this link: https://www.publicmobile.ca/get-started
10-22-2019 07:28 PM
Looking at the data from gsmarena, it looks like the phone will work. What is the source for this phone and is it unlocked?
10-22-2019 07:27 PM
@Habarc1 yes it is, I've got a friend on public mobile using one
