04-07-2019 05:12 PM - edited 01-05-2022 04:13 AM
I feel like I might have missed something, but how does PM know that the community account I am using is linked to the PM I using?. I don't remember any questions asking about my PM account. I felt like when I signed up, the accounts were seperate.
04-07-2019 07:00 PM
@disneybear15 wrote:I feel like I might have missed something, but how does PM know that the community account I am using is linked to the PM I using?. I don't remember any questions asking about my PM account. I felt like when I signed up, the accounts were seperate.
You are correct they are two different accounts that is why you should use the same email address when setting them up. If you send the moderators a private message they will more than likely ask you to verify your account by sending you a link that you must enter your authentication details as described in the previous post.
04-07-2019 05:24 PM - edited 04-07-2019 05:30 PM
Yes they are separate. In a case you need the support where your pm account and sensitive information would be shared, you would contact them through community account, then moderator would verify you are pm account holder.
04-07-2019 05:22 PM
I am sure it's been asked before:
04-07-2019 05:18 PM
@disneybear15 If you use the same email address as your PM account the moderators should be able to see both accounts linked to your email address.
04-07-2019 05:15 PM - edited 04-07-2019 05:16 PM
Your 2 accounts are linked with your email adress. And yes they are separate because you need different usernames and passwords to open each .![]()
