03-21-2019 09:31 AM - edited 01-05-2022 03:51 AM
Hello,
I am a Koodo customer coming to Public Mobile. In the Public Mobile account setup for Koodo customers it says to pick a new number and then "contact us" to transfer the old Koodo number. Who exactly do I contact?
Thanks,
Kov
Joining Public
03-21-2019 10:53 AM
@ShawnC13 wrote:
@mh1983 wrote:Do you guys know if the "change email account tied to Koodo" tip is still suggested? I signed up this way and it worked well. I saw an old thread on the matter too, but may be an out of date thing. Do ports happen seamlessly now, regardless of the same email on Koodo postpaid and PM prepaid?
I would still avoid using the same email. I am not sure if it was just an issue if you were prepaid with koodo or not. I just wouldn't want to tempt the PM systems to run smoothly
I've used the same email for Koodo prepaid and PM without any issues.Don't think it's an issue.
03-21-2019 10:06 AM
All done. Thanks a lot for your help.
Cheers,
Kovie
03-21-2019 09:52 AM
03-21-2019 09:52 AM
03-21-2019 09:50 AM
@Kovalchuk wrote:@ShawnC13 Where does one go to port the number? Is that on Koodo's website or somewhere in my Public mobile account page?
Through the PM self serve portal. Login and you will want to find change number. There it will ask if you want to port in a land line or a number from another cellular provider.
03-21-2019 09:47 AM
03-21-2019 09:47 AM
03-21-2019 09:43 AM
@Kovalchuk wrote:Hello,
Thanks,
Kov
@Kovalchuk, you only need to contact the Moderators if you are coming from Koodo Prepaid. If you are a post paid account you can do the port in of your number through the self serve on your own.
03-21-2019 09:33 AM
My man.
Thx 🙂
03-21-2019 09:32 AM
