Code refer a friend
11-16-2022 05:58 PM
11-17-2022 06:26 AM
There are many social media sites you can share your special referal code! I advise Reddit. Otherwise, you sharing the code allows others to recieve a $10 discount as well as have you earn rewards. Read more about your PB rewards on the "My Rewards" section when you sign in.
11-16-2022 06:02 PM
thank you
11-16-2022 06:01 PM
HI @Blu68 if you have not activated yet, there is a step during activation for you to enter the code
But if you have activated but forgotten to put that in, and you have just activated not long ago, maybe CS agent can manually apply it back for you
Just open ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
11-16-2022 06:00 PM
You enter it in during activation on the payment screen. Be sure to click Add and hope for the green checkmark.
I just tested a possible one that someone had posted and it came up invalid. Maybe they suspended their account.
