09-04-2020 10:19 AM - edited 01-05-2022 01:04 PM
I wanted to check with the community if anybody has experience with this and has the answer. I couldn't find the answer in the old posts.
The form to transfer a VoIP number contains the line
old account password
Usually th VoIP account has at least couple of password, one for account web portal and one for sip login. Does anybody out there know which one are they referring to?
Thanks
09-15-2020 04:59 PM
Ok just in case anybody else runs into this, I've contacted moderates and they gave me the list of info they need to port the VoIP number and it doesn't contain the password.
The form is probably outdated or it's also used for landline numbers that have pins. The list does contain the account number which is not in the form.
So my advice for it is either fill it in with all the info you have, leave the password blank and put your account number on comments (indicating it's the account number) and hope it goes true (wait by the alternative number you provided) or do the safer thing (which I highly advise) activate your account with temporary password and ask moderators to make transfer for you. They will provide you with the list they need for the transfer and will be able to clarify any ambiguity if any before the transfer is submitted.
09-04-2020 11:28 AM
@cavemantoronto you mean web portal or sip portal
I see account password in the sipbox/softphone and I see account password for profile login, but they are different, they both are account passwords but they should not be same
09-04-2020 10:26 AM - edited 09-04-2020 10:26 AM
@kselmak it's the account login password.
